Hi Inkochnito ,
I ran some tests that were suggested in the links you sent me.
I grounded the slingshot coils to the non-banded side and both left and right ignite
When I ground the MosFET on Q3 and Q4, slingshot coils don’t ignite
With the driver board removed:
Q3 MosFET from center to right reads 8.13
Q3 MosFET from center to left flashes a number and returns to 0.
Q4 MosFET from center to right reads 14.64
Q4 MosFET from center to left had no reaction.
I measured another MosFET just to see any similarities:
Q16 MosFET from center to right reads 8.11
Q16 MosFET from center to left flashes a number and returns to 0.
Diode Test:
Q3 measured 10.03
Q4 measured 9.93
Q16 measured 9.94
My thoughts are that Q4 is definitely bad and that Q3 even though it tested properly should also be replaced because the coils are not igniting when the MosFET is grounded. Note: The link stated that the tests are not 100% accurate.
Let me know your thoughts.
Thanks Peter,
Troy
