Hello everyone
First of all thanks for help !!!!!
Finishing the restoration of a mario brow pinball ( blue one ) here’s the last bug.
When multiball is lit and ball in the hole, a second ball arrives in the launch and nothing happens for minutes.
Game after one minute waiting doesn’t launch solenoids or pop up kickers for a ball searching.
You have to shut off the pinball or press credit for a new game and the balls are kicked out.
Also while playing flipper could stop working thinking a ball is lost ... and after that for the next ball, 2 balls arrive in the launch kicker and for the third ball too.
I’ve check cpu ( another one)
Check all the switch via switch test ( all working fine at each test )
Resoldered coils and solenoid test is fine.
Contact spray in micro switch and already check the space between contact in each of them.
Check all the micro switches they all work fine.
The only thing I saw is a lamp not working on a lamp board ... it could generates faults via lamp matrix ...?
And clue or idea ? Thanks a lot for help
Charlie
