(Topic ID: 288740)
Super Mario Bros Mods
By Lucxor
There are 62 posts in this topic. You are on page 1 of 2.
#1 3 years ago
So Because i actually do a Lot of Smaller Mods wich can be Printed.
I Wanted to Open a seperate Topic, so the others will not get over spamed.
Updates/Pictures and files will be shared here.
Also bring your ideas how we can make that game even more enjoable.
Files are Here:
https://www.thingiverse.com/lucxor/designs
ombi (resized).pngombi (resized).pngombi 1 (resized).pngombi 1 (resized).pngqube (resized).pngqube (resized).pngquestionmark (resized).pngquestionmark (resized).png
#2 3 years ago
I'm test printing the hollow block today. My first attempt I foolishly forgot to add extra supports in the hollow spaces. It did not go well I added them in the slicer for this go and will confirm proper fit on the FDM printers. After, I will print the block in yellow (need to get filament) and the question mark itself in white.
#3 3 years ago
Quoted from setzkor:
Thanks for trying
Nice if it works
Like I said I have done another file wich will work fine for fdm printer. It is not finished jet but I can upload a test file tomorrow.
if you like to try it out.
Same idea but not hollowed.
If you have some other ideas let me know
#4 3 years ago
Upgradet the Questionmark and the box a bit so hoppfuly it will fit better.
Uploaded the files.
test them tomorrow.
#5 3 years ago
The New Sla Works fine.
So the questionblock is finished.
Add the Questionblock for FDM printers.
can not try them. Let me know if they work.
Bild 1 (resized).PNGBild 1 (resized).PNGBild 2 (resized).PNGBild 2 (resized).PNGIMG_20210227_155424[1721] (resized).jpgIMG_20210227_155424[1721] (resized).jpg
#6 3 years ago
I the beginning when i got te pinball i have done some Aproncards for 3D printing.
if you are intresested lett me Know.
Meanwhile im working on something wich disturbs me and will help if you got A MULTIBALL.
IMG_20210227_234732[1725] (resized).jpgIMG_20210227_234732[1725] (resized).jpgbild 1 (resized).PNGbild 1 (resized).PNGbild 2 (resized).PNGbild 2 (resized).PNG
#7 3 years ago
I test printed the block today it went fine. I think I'll try the SLA model which prints with the right support settings. My yellow filament is in next week I'll do the final then
I was trying to figure out a place to put a Yoshi. That upper playfield area doesn't have a good place...
#8 3 years ago
Good to hear.
Let me know if the SLA works also for FDM
Can't wait to see when your finished.
O think there is a lot of space for a Yoshi
When I bought the Mario the preeowner has installed 2 Figures.
IMG_20210228_092030.jpgIMG_20210228_092030.jpgIMG_20210228_092538.jpgIMG_20210228_092538.jpg
#9 3 years ago
quick update
after i repaired my fdm 3 d Printer i was able to do some prototypes.
It disturbs me that the kiker on the rigth side is to low. because of the woodpart.
So when you have a multibal and there are more Balls in that lane, the pinball hase some problem untill he can throw all balls out.
i wantet that to make that the balls are guided and one after the other will ejected without that the next ball is blocking this one.
hope this is understandble in my english vocabular..
do you have the same problem or is this only on my machine?
are you interestet in this?
you can see my lane is brocken but i will do it that it will fit on a not brocken lane.
im in the final prototyp phase it just needs onla a little more change so all works great and well
IMG_20210303_173222[1734] (resized).jpgIMG_20210303_173222[1734] (resized).jpgIMG_20210303_173302[1733] (resized).jpgIMG_20210303_173302[1733] (resized).jpgIMG_20210303_174856[1732] (resized).jpgIMG_20210303_174856[1732] (resized).jpg
#10 3 years ago
Yes, I can have the same issue if I am too fast hitting into the castle (rarely happens) or if I hit an additional ball into the Question shot at the same time a ball is coming down from the castle. I actually just consider it part of gameplay and try to not do that, especially if it tries to hit both balls out at once and they go down the middle.
I am still waiting on my yellow filament, then I will print the block and install with pictures.
#11 3 years ago
Finally got my yellow in... That color in particular seems hard to find right now. My 2 part print is finished. I think it turned out well. I did modify the question marks to add a lip so that they "clicked" in place into the block.PXL_20210305_155958957 (resized).jpgPXL_20210305_155958957 (resized).jpg
I preferred that over glue. I can share that modified file if there is interest. In the machine I think it fits in quite well... granted the lamp is still too bright.
Now that I have yellow, I may tackle that warp pipe next... Those zip ties bug me.
#12 3 years ago
Finally got my yellow in... That color in particular seems hard to find right now. My 2 part print is finished. I think it turned out well. I did modify the question marks to add a lip so that they "clicked" in place into the block.[quoted image]
That looks Perefkt. I think there are some people how would like to have your updatetd Files
The Yellow would be perfect for that pipe. Im curious what you ar doing there.
#13 3 years ago
So a Little Update.
I changed the file for more improfments.
still not Perfect but now it has no problem to eject the balls. 3 balls in 3 seconds
in the Video you can see the secend one is still stuck. i working on a last final try this should fix it.
Video Here:
https://photos.app.goo.gl/oC8P4PZfP7kr14u28
#14 3 years ago
I've got the pipe drawn up, I made some brackets to hold it to the wireform and avoid the zip ties. I tested the bracket design today, it held very tightly. I'll test print the full pipe tomorrow and if it goes well, upload either here or to thingiverse.
#15 3 years ago
I've got the pipe drawn up, I made some brackets to hold it to the wireform and avoid the zip ties. I tested the bracket design today, it held very tightly. I'll test print the full pipe tomorrow and if it goes well, upload either here or to thingiverse.[quoted image]
Nice Job
Woul like to try it out when you're finish.
#16 3 years ago
I had been using Tinkercad for the design...I did not realize the limitation on segments for circles. I have 2 sets of files here
https://drive.google.com/drive/folders/11S8RnVwfQDxKy6VENp_WMJ-9zeGLtgQC?usp=sharing
that come from that program. On my printer, even at the highest segment setting, I am not sure I am happy with the "circular" shape of the pipe. I may try to revise on a different program.
There are 2 versions at the link, one with 2 sided brackets, meaning the bracket will be visible at the player location. The second, I removed half of the bracket on the player side to make it appear to be floating. Both versions in my test prints held well to the wireform. Obviously, the 2 sided bracket was much harder to remove, but I think neither would slip. I personally will go for the 1 sided version.
For reference, the picture is of the wireform (out of the machine) with the single side bracket printed at the highest segment setting possible. As you can see, the bracket is not visible (but my cracked original is...) but possibly also visible is some segmentation in the curve.
#17 3 years ago
Works great on my Machine.
I like how simple it is designed.
Holds very thight.
I thinking on make a second shorter one. wich goes on the lower part of the guide.
Thanks for sharing.
#18 3 years ago
Nice, glad it worked out. It is always good to confirm that the bracket works on someone else's wire form.
I'm wondering if to put one lower, the pipe would need to be thinner, and the brackets closer to avoid the ball hanging up? I tried to leave this one the same dimensions as the original, only hollowing out a small portion of the larger part of the pipe.
#19 3 years ago
It seems that it's possible to take the same pipe.
Just needs to be shorten mirrored and to do 2 cutouts so the pipe is on the same level as the wire form to provide that the bal could run thru.
It's a bit to long and the cut outs a bit too less.
Upgrade this a bit and then I also can share it.
Would be funny if the pipe would be bent as the wire form.
IMG_20210310_214921.jpgIMG_20210310_214921.jpgIMG_20210310_214948.jpgIMG_20210310_214948.jpg
#20 3 years ago
Would love to try these out if I can get me a SM pin. One of these days
#21 3 years ago
Quoted from Lucxor:
Would be funny if the pipe would be bent as the wire form. [quoted image][quoted image]
Looks good, let me know if you need anything from me, I can upload an STL or OBJ of just the bracket for instance if it would be useful, then you could rotate as needed to get the right angles for that lower pipe.
#22 3 years ago
Ok, I figured out enough of FreeCAD to make a cleaner file for the single sided bracket, I will upload the new STL and STEP files at my link above. I think this one should print without the segments from before.
#23 3 years ago
A Stl from the brackets would be helpful.
then I could try a bent pipe.
#24 3 years ago
Ok, I uploaded 2 additional STL, a Single sided bracket that has been hollowed out where the pipe is. and a second two sided bracket with the frame that I used to hold together/center it in the pipe. It will need then to have a hole/pocket put in to fit through the pipe. Note: to make the double sided bracket single sided, you need to pull 5mm off of the desired side.
Link again...
#25 3 years ago
Link again...
I designed a bent pipe with the two holders.
After 4 diffrent trys this one worked. Maybe there are some improvements to do, but i like it and it works well.
I have uploaded the files.
IMG_20210314_194747[1769] (resized).jpgIMG_20210314_194747[1769] (resized).jpgIMG_20210314_194755[1768] (resized).jpgIMG_20210314_194755[1768] (resized).jpg
#26 3 years ago
All of these mods have inspired me to tear down for a cleaning... Once I put it back together all the new stuff goes in...
#27 3 years ago
Nice.
Don't forget to Keep your parts save and organized
#28 3 years ago
I like what you guys have been up to. Here's a few that I can add.
Speaker lights that don't require you to modify the speaker panel, https://www.thingiverse.com/thing:4797571.
Themed flipper buttons, https://www.thingiverse.com/thing:3724620.
#29 3 years ago
Quoted from latenite04:
Love It. Thank you for sharing!
Have to try them out in the next free time I have
#30 3 years ago
So i Uploaded all my designes on Thingverse. also the Apron Cards.
Link is Here: https://www.thingiverse.com/lucxor/designs
setzkor i also uploaded the bent pipe with the holders you designed, i wrote that the holder are from you i hope that is okey.
if not tell me and i take the pipe down.
#31 3 years ago
No problem, I will upload the modified question marks that snap in for the block as well. Then you can add them to the thingiverse listing.
#32 3 years ago
Thank you i have added it to the questionmark on thingverse to download.
Have to work on the kikout file. still not finish jet.
#33 3 years ago
Got my pipes finished and installed. Big difference from stock... Definitely an improvement. These are printed in PLA+, I'll see how they hold up, ideally I think they would be in ABS or at least PETg.
IMG_20210403_230329 (resized).jpgIMG_20210403_230329 (resized).jpgPXL_20210404_035852615 (resized).jpgPXL_20210404_035852615 (resized).jpg
#34 3 years ago
"I gotta get a Yoshi!"PXL_20210414_003600443 (resized).jpgPXL_20210414_003600443 (resized).jpg
So I'm making one...
#35 3 years ago
Ok, I think I've got it the way I like it. Fits under the glass... But not a whole lot of room to spare
2 months later
#36 3 years ago
I finally got around to painting and getting the full thing installed. I have also uploaded the design files to thingiverse:
https://www.thingiverse.com/thing:4894044
#37 3 years ago
https://www.thingiverse.com/thing:4894044[quoted image]
Love it amazing work
3 months later
#38 2 years ago
Found a little snes controller, and 35th anniversary pins to add. Came out pretty good
32255FCE-7C18-4809-807C-AF08C30AA216 (resized).jpeg32255FCE-7C18-4809-807C-AF08C30AA216 (resized).jpeg4387A1BD-30F8-40F0-B093-43BDCEB501B6 (resized).jpeg4387A1BD-30F8-40F0-B093-43BDCEB501B6 (resized).jpegFAE6C7D6-C9A4-4ECD-8E97-6A3D4B748571 (resized).jpegFAE6C7D6-C9A4-4ECD-8E97-6A3D4B748571 (resized).jpeg
#39 2 years ago
Quoted from ish08kazuya:
Nice!
where did you found it?
1 month later
#40 2 years ago
Hi,
I don't suppose anyone has scan of the Super Mario Bros playfield and speaker panel available? I'm currently trying to restore a very heavily played SMB that's missing the speaker panel.
#41 2 years ago
Quoted from 8bit-1up:
Hi,
Check him out for the SP
https://xianek.eu/
#42 2 years ago
where did you found this?
#43 2 years ago
Quoted from Lucxor:
I bought it years ago from a japanese vending machine when i was there. Im sure ebay would have some hopefully
1 month later
#44 2 years ago
Custom lite flipper bats
F0350B7C-42EC-43FE-88A2-76A7511787F7 (resized).jpegF0350B7C-42EC-43FE-88A2-76A7511787F7 (resized).jpeg
#45 2 years ago
I went a different route when 3d printing the question blocks. I printed in black filament and painted over in yellow. Then stuck white card stock inside. I think it looks better for those that want LED flashers without the insane brightness
3ACD2084-C0DC-4DA3-84B9-E99583D1831F (resized).jpeg3ACD2084-C0DC-4DA3-84B9-E99583D1831F (resized).jpeg
#46 2 years ago
Great idea
I also like the dog in the back.
1 month later
#47 2 years ago
I have the playfield scan
#48 2 years ago
Quoted from ClarkKent:
Nice. Id love to either have them or someone could print them out to restore a playfield i have
#49 2 years ago
Changed to red lite flippers and looks really good
727A77F4-6B18-4994-AD6C-738A5434EA18 (resized).jpeg727A77F4-6B18-4994-AD6C-738A5434EA18 (resized).jpegCD2D7B1E-85CA-40CE-A265-FC8DB021DCC8 (resized).jpegCD2D7B1E-85CA-40CE-A265-FC8DB021DCC8 (resized).jpeg
3 weeks later
#50 2 years ago
Anyone have a STL of the pipes that fit over the flashers?
I also added a bowser next to the castle. It was a $15 bowser on eBay. I cut his legs at an angle. Looks like his legs are inside the plastic ramp, and the ball travels between his legs. I like it!
C3529D2F-2017-4C67-A392-6BAD7C9ABA7C (resized).jpegC3529D2F-2017-4C67-A392-6BAD7C9ABA7C (resized).jpeg
$ 5.00
Whitty Pinball Creations
Uberlaser
Macomb, MI
Daddio's 3D Printed Mods
$ 68.00
Slipstream Mod Shop
$ 14.99
$ 19.99
$ 39.99
$ 1.99
Great pinball charity
Pinball Edu
