(Topic ID: 357766)
Suggestions Please for Straightening a Warped Ramp Plastic
By Rikoshay
6 days ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 5 days ago by Rikoshay
#1 6 days ago
Hi All,
At first, I assumed this ramp plastic was normal, but the more I looked at it it just doesn't seem right so I checked IPDB and it appears that my ramp is warped.
Don't understand why as there's no lamps under or nearby.
It the left ramp from a Gottlieb System 3 Gladiators.
I can post better more detailed pics if anyone thinks it will help.
The left hand side is.......sort of curled over to the left more, right hand side on picture, not vertical as I'd like it to be.
It also appears that Gottlieb at the time painted the outside of the ramps in silver and I'm not sure how to tackle this correctly without wrecking/removing any paint.
You can see the warp where the plug and look is hanging over.
Any help/advice much appreciated.
Thanks.
#2 6 days ago
You will have to create some sort of jig and put it into the oven at the lowest setting.
#3 6 days ago
I'd just heat it with a heat gun and bend it as you need to.
#4 6 days ago
Quoted from Pablito350:
Without a jig, you risk deforming it in undesirable ways.
#5 6 days ago
thanks for the prompt replies......but yes I did consider a length of timber as a support/brace and held in place with plastic clamps, but which side to put the support on?
If I put it on the outside, I run the risk of possibly due to my error, ruining the inside that is seen if it goes pear shaped.
If I put it on the inside, I run the risk of ruining the silver paint that you see from the inside.
I don't have any other ramps to practice on.
Yep I'm a pessimist but thinking realistically.
My concern with using the oven is that the ramp may distort elsewhere there isn't a jig.
Still open to more suggestions, or tell me "this is what you do".
#6 5 days ago
Does it really effect the ball, or is this just cosmetic? If cosmetic, I would just leave it alone.
#7 5 days ago
i never played the game believe it or not.
was missing numerous parts of both lower flipper assemblies but it powered up......then straight into tear down.
i did think of leaving it alone as once any damage is done there's no going back.
$ 1.00
Pinball Alley
2,399
Wichita, KS
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/suggestions-please-for-straightening-a-warp-ramp-plastic- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
