(Topic ID: 252420)
Suggestions/Help - move pins down brick stairs
By krustykramer
48 days ago
  • 12 posts
  • 9 Pinsiders participating
  • Latest reply 47 days ago by Pinstein
    #1 48 days ago
    Hi- I'm eager to purchase my first pin and am looking for suggestions on how to get my first one down the stairs into my basement before I actually pull the trigger (first things first!) . I've attached some pictures of the stairs and landing and I'm sure someone has already figured out a creative way to solve this challenge.
    I'm open to purchasing a reasonably priced hand truck but as you can see from the picture, getting the pin up over the ledge is a little tricky. Also have considered getting a piece of plywood, cutting it down to 3 feet wide, wrapping it with some pin-safe material and possibly sliding the pin down the stairs?
    Pictures attached...
    Next house will have flat daylight basement access! Once solved then I need to decide if I'll get a DP premium, ACNC, or JP - that will be my next post.
    TIA and LMK if you have any clarification questions!
    IMG_4522 (resized).jpegIMG_4525 (resized).jpegIMG_4523 (resized).jpegIMG_4524 (resized).jpeg
    #2 48 days ago
    I suggest that you enlist 4 fully grown men that weigh at least 200 pounds each and carry it down the stairs.
    They should be healthy with no back issues or other problems along that line.
    Perhaps if you fit that criteria, you only need 3 more.
    #3 48 days ago
    Get a furniture dolly strap the game have two people one lowering it and one on the bottom holding. Are basement stairs are similar to your but with more steps me and my dad do it all the time has become very easy over time.
    #4 48 days ago
    Yuck, I thought my house was bad. You poor poor soul.
    #5 48 days ago
    If you are short on help you can always remove legs, remove head, remove glass and remove the playfield. Carry all parts down separate. Reassemble. The cabinet is a hell of a lot lighter without a playfield. Easy job for two people.
    #6 48 days ago
    I think the best approach is the more manpower the better. Make sure to take the head off if possible. Looks like you can carry it down the stairs and then tip it up on its back. Pins are really heavy if you don’t know that already.
    #7 48 days ago
    Thanks for the feedback.
    I should have mentioned that I already have taken three video games down these stairs with my son. We realized very quickly we were over matched and bailed. Second time, I removed the monitor and it wasn't too bad but the biggest challenge is getting it over the ledge without scratching anything. I'm not as concerned about old vids but it's a whole new ball game with a new pin.
    It sounds like some form of disassembly might be the best approach but can you remove the head from *all* pins? How hard is it to remove the play field?
    #8 48 days ago
    Removing the playfield makes the Pin lighter, but not smaller. I say leave it on and just get extra help if it’s too heavy.
    #9 48 days ago
    Just be aware that some of those games are especially heavy.
    You might even want a 5th small person to hold the door open, hold the power cord or give the big guys water or whatever.
    Guys in that weight range will probably need something to eat too before the deed is done.
    #10 48 days ago
    i am thinking take the head off, pull the playfield out, take it down piece by piece......
    #11 47 days ago
    Quoted from krustykramer:
    You could try using 3/4" plywood to make a ramp up the ledge, strapping the game on a hand truck with sleds But it definitely looks like a tight pivot.
    #12 47 days ago
    You don't need a hand truck you need an engine jack or some pulley set up so you can just drop them straight down to the door.
    $ 229.99
    $ 5,599.00
    Operation Pinball
    $ 24.99
    Lee's Parts
    $ 2,000.00
    Great American Pinball
    $ 48.25
    The MOD Couple
    Hardware
    Filament Printing
    $ 135.00
    Cabinet - (Alt) Translites
    Lit Frames
    $ 7,995.00
    Classic Game Rooms
    $ 154.00
    Id Rather Play Pinball
    $ 129.00
    LED OCD
    $ 100.00
    $ 200.00
    Professor Pinball
    $ 27.50
    The MOD Couple
    $ 239.00
    $ 12.00
    Flashinstinct
    Professor Pinball
    $ 239.99
    PinballBulbs
    Medisinyl Mods
    $ 9,999.99
    Little Shop Of Games
    Metal-Mods
