Suggestion please
(Topic ID: 34346)
Suggestion please
By Fishmugger
5 years ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by SealClubber
#1 5 years ago
Pick up a prestine balley fireball 2 . Have owned this pin before and sold my last one trading for upgrade.This pin looks as new and from what i can tell cant find any evidence of ever been worked on. It worked for a few weeks then quit. Problem is now will not start up. It does turn on and all lights fire up but game will not take any credits or will not deliver ball to shooting slot. Mpu board flashes correctly 6 times so don't believe problem is there . Test switch on door does not fire solenoids . Capacitors I know can dry up over time and they look original .do you think that is where to start . Any ideas to send me in the right direction is greatly appreciated .
#2 5 years ago
check fusses special for the one of solenoids 43 Vcc ?
#3 5 years ago
Check the 1A fuse under the playfield as well as the ones on the Power Control Board (PCB)
If that doesn't fix it, need to check voltages.
What are the voltage readings at the test points on the PCB, MPU and Solenoid Driver Board?
$ 16.00
Yorktown Parts and Equip
€ 3.95
Multigame
$ 99.99
$ 12.95
$ 170.00
Pin Mods
$ 60.00
Mods for your pinballs
