(Topic ID: 215307)
Suddenly getting airballs - ideas of the cause?
By Fezmid
6 years ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by Fezmid
#1 6 years ago
So this is probably a dumb question, but I couldn't find another thread on it so figured I'd ask here and hope for the best... Don't laugh at me too hard.
I haven't made any changes to my MET Pre in about 4 months (that's when I last cleaned/waxed it). When I was playing last night, I started getting a bunch of airballs - including two that bounced off of the right bumper and hit the glass! It wasn't confined to that though - I hit a post by a ramp once, and it jumped up and flew up, and I hit something else once and also got an air ball. All of this in 2-3 games.
It was late, so I didn't have time to investigate at all, but I figured there'd be a thread about common causes -- unfortunately, I couldn't find one.
So is this just an indication that I waited too long before waxing again (been a few hundred plays in that time)? Should I look at the balls? Are the rubbers getting worn? Or just a coincidence? Just looking for what I should be focusing on, although I'll look at all of it I'm sure.
Thanks all!
#2 6 years ago
Waxing would generally make airballs worse as their is more speed with the ball and new rubbers do the same as their is more bounce.
What exactly is causing the air balls? Is it the stand-up targets or the post with mini rubbers on them?
Mini-rubbers - Check to make sure they are still at the proper height. Sometimes they can work their way down a bit which will cause airballs.
Mini-targets - Depending on the number of plays the foam behind the target could be getting old thus allowing them to lean back more when hit which will also cause an airball.
#3 6 years ago
Quoted from 85vett:
Good to know, thanks!
From what I can tell, I was getting airballs in the following locations:
1) Right bumper -- maybe the rubber lowered, so I should look and raise it back up if possible as it happened twice here
2) Near right ramp -- didn't hit the ramp well, and it bounced up and to the left; it's possible I hit the pick target, not sure. I suppose based on what you said, it could be the flipper rubber that's nudged down somewhat and giving the ball a little air when I shoot, and then when it hits a target, it flies up even higher? Maybe that's the first place I should look?
Can't remember the other location I had one...
When you say "mini targets," what are you referring to? I didn't realize there was foam anywhere (constantly learning).
#4 6 years ago
Also make sure your flipper rubbers are still in position. If they're not resting on the little ledge of the bat fine it can cause issues
#5 6 years ago
Quoted from Fezmid:
Those are the pick targets. Their should be black foam behind them which helps absorb the hit on the target and also limit its travel back.
If you are talking about a pop bumper that can't be adjusted and will happen from time to time.
#6 6 years ago
Quoted from 85vett:
Oh, cool, I'll have to look at the pick targets a little closer. I didn't realize there was foam there, so I'll see if something seems off with the one versus the other three. Thanks!
$ 22.50
$ 19.95
SilverBall Designs
$ 9.95
Mitchell Lighting
$ 69.99
$ 29.95
SilverBall Designs
$ 18.00
Volcano Pinball
10,999
$ 69.99
$ 29.95
$ 200.00
Professor Pinball
$ 1.00
Mitchell Lighting
$ 9.99
Bent Mods
$ 25.50
10,600
$ 14.00
SilverBall Designs
$ 64.00
Lighting - Under Cabinet
10,650
Ontario, CA
Lighting - Backbox
$ 12.95
$ 69.99
$ 7.00
Pinball Z
Filament Printing
$ 99.99
$ 160.00
Sparky Pinball
11,600 (OBO)
Lubbock, TX
$ 55.00
The Flipper Room
This page was printed from https://pinside.com/pinball/forum/topic/suddenly-getting-airballs-ideas-of-the-cause and we tried optimising it for printing. Some page elements may have been deliberately hidden.
