Hi,
today I had time to check some things.
1. I unplugged the harnes to the coin door. No difference.
2. I deconnect and afterwards I connect the slam switch again. No difference.
3. I checked the test switch. Multimeter says value about 0,6 - I think that is okay
4. Yes, I got zeros as soon as I turn power on. Later I can check the wires of the slam tilt.
5. That is a litte bit confused: I can play, when I put manually a ball in the play field. All solenoid seems to work and I can operate the flipper arms. But no sound and no score countings.
Then I noticed a bad smell - The solenoid (see picture) got very hot!
I marked it on the pictures. It seems, that this controll the ball throw-in. When I turn power off, the pin move back. I think the solenoid
is okay, but the controll has an error. May something stuck.
What do you think?
