Decided to pull out one of my old retired Hakkos (I have two of these) that had nearly no suction and clean out the pump valve...
Hakko 700C Desoldering station front
Hakko 700C Desoldering station internal
Vacuum suction measured around 100mm-Hg (3.9 in-Hg) at the stations inlet
Diaphragm is still ok
Valve is under the metal disk
Ahh, it's full of solder resin. Hang on, I see some tongue shapes in there. No this brown mess is the valve that's perished!!
Made a replacement valve from a piece of rubber
Cleaned out the crap from the valve cover and installed the replacement valve
Now that's better suction! Vacuum suction measured around 585mm-Hg (23 in-Hg) at the stations inlet
Irons
Unfortunately replacement tips for the desoldering gun haven't been available for many many years..
