(Topic ID: 246491)
Subway 1 Point relay Locking On
By tscottn
7 months ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 7 months ago by jrpinball
#1 7 months ago
Hi guys,
I have been slowly restoring a Subway I picked up a few weeks ago. I have a issue with what appears to be a 1s scoring issues. If the 1 point reel is on any number except zero the machine will reset fine, as soon as I score anything from a 1 point switch, the N relay in the backbox will lock on with a loud buzzing and the score real will not increment to the next number.. If I manually press the plunger on the 1 point reel to increment the reel, the N relay will reset. This will continually happen.. Note that 10 points and 100 and 1000 points are not affected at all.. only the 1 point switches.
Also, if the 1s reel is at the zero position when the machine is powered up, everything will reset but the N relay will be locked on until I manually press the plunger on the 1s reel to increment the number, but like i mentioned, if the 1s reel is on any number EXCEPT the zero position when powered up,the reel will reset to zero and the N relay will not lock on until I press any 1 point switch, then it will lock on until I move the reel to the next number.
Just a note, I replaced the flippers and pop bumpers with high powered coils, but I dont think that should be a issue. I also moved the power from Hightap to normal as it was on Hightap when I got the machine.
Thanks for any help you can give..
#2 7 months ago
If it all worked ok since working on the pop bumpers, I think these score 1 point if un-lit. Have you examined the connections on these in case you've put a short circuit in there somwhere?
#3 7 months ago
Reply sent in private message
#4 7 months ago
Quoted from tscottn:
Why? Properly shopped, the action of the pop bumpers and the flipper strength is more than adequate.
It's your game, so do what you want to it, but I just don't understand the need to hot-rod games which were designed by guys who forgot more than we'll ever know!
#5 7 months ago
Good move though removing the high-tap. No need to overstress the non-gameplay components.
$ 50.00
$ 400.00
Playfields
Maple Street Sign Shop
$ 11.00
Music City Pinball
$ 90.00
Geeteoh Electronics
$ 22.00
$ 9,099.00
Operation Pinball
$ 24.99
Lee's Parts
$ 78.00
$ 22.00
$ 154.00
Id Rather Play Pinball
$ 7,599.00
Classic Game Rooms
$ 229.00
Tilttopper
Flashinstinct
$ 99.00
Lighting - Under Cabinet
