I'm currently renting a beautiful modern remake of a classic Williams pin. I keep in my basement, on a rug. A couple days ago, a Nor-easter came through, dumping tons of rain outside. Some of the rain seeped through the wall at floor level near the pin, creating little puddles in limited areas of the floor. It's also soaked the rug upon which the pin stands. The floor puddles aren't deep at all, and I've mopped most of them up. The pin itself is not sitting in a puddle (i.e., no water is above the foot, although I assume there's quite a bit of water under the rug). I unplugged the pin before the storm started and the plug is way off the floor. The only place where water touches the pin is on the feet of the metal legs, which are bolted into the wood corners and I assume aren't anywhere close to where electrical connections would be.
My question is: Did I risk electrocution if I plug the pin back in and play in? There's no water anywhere near any electronical components. The plug will never be anywhere near any future puddles. There's no water where I'm standing to play the pin.
Unfortunately, the pin is too heavy for me to move and there's other place I can put it anyway.
