(Topic ID: 329990)
Stumped-Lucky Ace ball release
By lorenb
2 days ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 1 day ago by paulace
#1 2 days ago
I have a Lucky Ace that is playing as it should except for one thing. When the ball drains or a start of new game the machine goes through all startup and eject ball to shooter. The score motor continues to run which continues to pulse the ball eject coil even though the ball is already in the shooter lane. It will sometime run 2 more times, sometimes no extra turns, and sometimes 5-6. It always does complete the cycle and starts the game. The bonus works as it should and is pulsed to initial 1000. I’ve look at score motor contacts 4A, 5B, and 6B and they appear to be workings. I did notice, for whatever reason, that the outhole relay is locked and release as the problem stops. Any ideas? Thank you
#2 2 days ago
Is that switch on the Outhole Relay in its locking circuit opening? That switch is in series with the m/b Motor 5B switch and should have B-BLU and BLU-R wires.
There aren't that many switches that should be able to hold the Outhole Relay on:
#3 2 days ago
I think it is correct but will go back and double check. To me, something is driving the score motor and as a results the outhole relay and consequently the ball release coil.
#4 2 days ago
Quoted from lorenb:
I have a Lucky Ace that is playing as it should except for one thing. When the ball drains or a start of new game the machine goes through all startup and eject ball to shooter. The score motor continues to run which continues to pulse the ball eject coil even though the ball is already in the shooter lane. It will sometime run 2 more times, sometimes no extra turns, and sometimes 5-6. It always does complete the cycle and starts the game. The bonus works as it should and is pulsed to initial 1000. I’ve look at score motor contacts 4A, 5B, and 6B and they appear to be workings. I did notice, for whatever reason, that the outhole relay is locked and release as the problem stops. Any ideas? Thank you[quoted image]
I had a similar issue on mine, where the motor would run extra turns sometimes.
Although I did not have the outhole kicking additional times (that might be something else), I did have and issue where the score motor would rotate additional times. For me, I found that the inertia on the motor was enough to push it past the rest position of the cams. I ended up taking mine off hi-tap, and adding more tension to the switch stacks which seems to help stop the rotation at the appropriate spot.
There is also a bit of a race condition on some of the stacks, this is typically the bonus counter, where even tho it is on the same stack, one switch needs to close before the other.. or something like that.. but it doesn't sound like the bonus is your issue.
#5 2 days ago
There's a switch on the Outhole Relay that drives the score motor - not the other way around. As long as the Outhole Relay is locked on, the score motor will run. You're trying to figure out why the Outhole Relay is locked on.
#6 1 day ago
Paulace and others, thank you. This seemed so obvious but just could not see it. Turns out the outhole switch WAS the problem. I thought I could see a gap but apparently there was not enough and the machine vibrating caused an issue. This tech forum is the best.
#7 1 day ago
Glad you got if figured out.
$ 5.95
The Pinball Scientist
Protection
Men
Other
Other
Playfields
Detrick Pinball Shop
Playfields
$ 7.49
