I'm down to the last (I hope) major issue on my Freddy project. The glove flipper isn't working. This is a little challenging to troubleshoot. There is no flipper test in solenoid test, and the glove flipper only works when a relay is activated. The good news is, this is a simple flipper system and I'm totally stumped as to why it isn't working. Glove Flipper relay works in diagnostics. Pressing the relay manually gets me voltage on all 3 lugs, 62v (the other coils are getting 66). Grounding the non banded side of the other flippers activates the coil. Grounding the non banded side of the glove flipper does nothing. This was done while holding in the relay, there is voltage at the coil. The coil is brand new from PBR. I'm getting 4.5 ohms across the outside lugs. I'm getting 5.2 on the right flipper coil, and 16 ohms on the left flipper coil. This is clearly odd. Lower flippers work fine, and I think they are both new coils as well. Any ideas? I suppose I could swap the glove flipper coil to a known working setup, but I'm confident the coil is fine.
