I removed the plastics (and the eyes) and switched out the bulbs to leds. (Not any Flashers) When I finished and powered on everything looked nice and bright. Hit start and the score kept going up. Switch test looked like it was the three drop targets that were down and hadn’t reset. I looked under the playfield for loose wires and then powered on again after resetting the drop targets. Now the only solenoid that gets power are flippers.. did I blow a fuse on the board? There must be a short on the drop target coil? Trying to make sure looking in the right direction tomorw
