OMFG this thread is like talking to a bunch of folks with no ears or eyes lol. Either everyone is giving the wrong suggestions or the description of the problem is inaccurate. If this is caused by a board transistor as half the people here say is "1000%" the case, then the symptoms are different. Pay attention:
A transistor based problem - as soon as game powers on flipper is stuck on. This happens because the transistor is internally shorted and as soon as the game powers up the flipper becomes energized. Happens even before the game is done booting.
However, if the game requires pressing the start button or going into the test menu, then THIS IS NOT A TRANSISTOR PROBLEM. Instead, it's an issue somewhere in the cpu line where the cpu is telling the flipper to energize. This usually means the flipper switch is telling the cpu to energize the flipper.
But if we have absolutely eliminated the flipper switch (and I'm not sure we have as the photo shows upper flipper switch energized, and it's entirely possible stern switched the upper and lower right flipper switch wires at assembly time by accident) then there are other things that could cause a cpu to tell the flipper to energize. Some might be:
- bad connection on ribbon cables. Resets them all
- bad cpu or battery damage.
Something on these lines. The symptoms are important to diagnose the problem.
