I finally summoned the courage to disassemble and de-gum the bonus unit (had cleaned as best as I could without fully removing the shaft but was still hanging up occasionally). I'm confident I got everything back together and properly aligned, and that thing snaps back with authority now!
However, now when I fire the machine up it runs through the reset cycle and then immediately starts firing off 100 points over and over while the score motor runs.
I don't think anything I touched would cause this so I'm confused and not sure if it's just a coincidence brought on by tipping the playfield all the way up against the back box and down?
The only 100 point items are the 2 standup targets as far as I know. The drops score 300, which, actually I don't know how that works to repeat the 100 3x for each of those. The loop I'm stuck in now is a slower repeat than the quick 3x staccato of scoring 300 though.
Any advice?
