So Im dealing with a regular head bolt on a 80s Williams game, basically the female T nut has fallen out of the body wood groove and now I have a head bolt with a stuck on T nut that just keeps spinning.
I spent two hours with pliers, vice grips, and needle nose trying to hold the dropped out T nut and then crank the head bolt loose but it wont budge. I even tried to pull the head bolt upward with the back end of a hammer to get tension and try to loosen the head bolt still nothing.
I have a feeling the nut and bolt are somehow misthreaded over the years and now stripped.
Outside of a grinder or drilling out the top of the head bolt does anyone else have any other suggestions for this removal.
I have never dealt with a bolt this bad and I can really see why you should always throw a little grease in your body and leg bolts
