Strange problem just started in my Addams Family machine. The power will not stay on unless you press in and hold on the 5A Slow Blow Panel Mounted Fuse Holder near the on/off switch in the "Line Filter Assembly". When I pull the fuse holder out, the fuse is stuck inside the mechanism. Any trick to get the fuse out so i can try to reseat it properly or would I be better off just resoldering a replacement in? Thanks!
