Heat the bracket, not the screw... need to make the hole bigger, not the screw itself.
Can also dremel a full notch into the head, and try a big common screwdriver with vicegrips on the handle and a bunch of downward pressure while turning.
Tried heating it with my soldering iron. Could try again with the large tip.
If that doesn’t work, I guess I’ll make a large slot with the Dremel.
Quoted from undrdog:These screws are stuck like Chuck. No nuts on the back- the bracket is threaded .
Tried needle nose vice grips. They just slip off the rounded head. Tried some WD to penetrate.
Before I cut off the heads and drill out the screws, any ideas?[quoted image]
I have put vise grips on the threaded side of screws and broke them loose. That usually works. On the threaded side you want to tighten the screw so it goes the right direction on the other side. Once loose they usually come right out.
Easy/quick way is to use a dremel tool with a cutting blade. Put a straight deep slot into the head and you can turn out with large flat head screw driver. Works nearly every time for me.
Quoted from pinengineer77:Check to make sure there are no nuts on the back side of these screws. Some games have longer screws and nuts on the other side to prevent the screws from loosening. You will see this on WPC flipper bushings and have also seen it on Williams early SS flipper solenoid brackets too.
His first sentence said “no nuts on back”.
I see the heads have not stripped yet. Use the proper size phillips screwdriver and turn until your face turns blue. Thats pretty thin metal and your human strength should overcome the tiny bit of force the threads are having o the screw.
Or the screw will break.
Or the head will strip.
Cutting a better slot didn't work, nor did heating up the bracket with a solder iron.
Ended up cutting off the screw heads. That let me remove the coil stop, which left enough of the screw exposed so I could back it out with a pliers.
What should have been a 15 minute coil replacement ends up taking forever and I have to go buy new screws. But on the bright side, I have a shiny new pair of vice grip needle nose pliers from HF and I didn't have to remove and re-assemble the whole flipper assembly just because of two stuck screws.
Thanks for playing "15 Minute Projects That Take Hours". Tune in next time, when our PinRepairHobbiest says, "Damn! That whole thing just broke right off!"
Quoted from undrdog:Cutting a better slot didn't work, nor did heating up the bracket with a solder iron.
I've had coil stops welded on the coil bracket. Consider yourself lucky
This wouldn't be pinball if you didn't have to go through this every one in a while.
If the screw cannot be removed because it is rusted in place or the head breaks off, you can try an ease out kit to removed them.
This is not an easy process...
See attached.
https://www.lowes.com/pd/IRWIN-Hanson-10-Piece-Spiral-Screw-Extractor-and-Drill-Bit-Combo-Pack/1003018224
Bottom line is you did whatever it took to get the job done. End of story. Worst case scenario next time is you do the exact same thing but no time waisted having to ask. Another skill under the belt.
Quoted from undrdog:Wasn’t rusted at all! Maybe cold welded?
Sometimes, if the screw is turned too tight, the metal on the threads can be slightly deformed and cause it to get stuck in place.
Perhaps that is what happened.
This page was printed from https://pinside.com/pinball/forum/topic/stuck-coil-bracket-screws and we tried optimising it for printing. Some page elements may have been deliberately hidden.
