Having just picked one up, I'll list what I had to fix. Most of this is a repeat of what has been said already.
-The stand up target's actuator was broken
-Bad opto receiver for the left popper
-Divots in the ball trough that had to be filed out to keep balls from hanging up
-Left popper wouldn't reliably kick out balls when other balls were locked, needed adjustment
-Balls would get hung up when rolling from the underplayfield ramp into the left gun's popper
-Typical burned GI connectors
-One GI string was flaky, ended up being baked connections on the PDB from heat
-Had to resolder bulb holders on the large PCB for the ship's shield inserts
-Going to rebuild the cannon wiring harnesses as they have been hacked in the past
-Right flipper opto interrupter was wimpy and wouldn't fully block the beam, had to be replaced
If I can think of anything else, I'll add it later.
Edit, just thought of more:
-Cracked subway ramp at the Start Mission hole. I repaired it and ordered the protectors from Mantis Amusements
-Broken Start Mission scoop. Had it welded at a local shop.
-Broken left flipper base plate
-Broken pop bumper rod
