Good morning,
We changed the power board in the past so I played many games but once the pin restarted so I continued playing and then I smelled that something was burned so I turned it off. After some time I turned it on and now I have these problems:
The biggest problem is with both cannons. They are working correctly when I make the test but they don´t work during the game. It works same as when you turn them off in the menu so they are not used in the game and you don´t earn points during Battle Simulation.
I have also next problem. When I turn it on the ball is shooted by the plunger then it fall down between the flippers and then it is shooted again. This is still repeating until you start the game.
I am sorry but I am an amateur.
Thank you for the help.
