(Topic ID: 58906)
STTNG transistor upgrade
By adalogue
8 years ago
  • 12 posts
  • 7 Pinsiders participating
  • Latest reply 8 years ago by dsuperbee
  • Topic is favorited by 7 Pinsiders
#1 8 years ago
The Drop Target down xsistor seems to fail often, anyone ever try and Nte2343 as an upgrade? 120V 12A spec.
#2 8 years ago
Replacing a TIP102? Yea, the NTE2343 works fine.
#3 8 years ago
Not a fan of NTE parts. I think a TIP102 is your best option.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
#4 8 years ago
Yes, Tip102.
What issues have you has with NTE?
#5 8 years ago
Quoted from adalogue:
STTNG has 4 coils which are controlled from the auxiliary driver board. This board has an extra wire to the 50V, for a tieback diode. If this breaks or has a bad contact or so it tends to destroy transistors.
The droptarget coils and diverter coils are the ones that are controlled from this board.
I have seen many STTNGs that have burnt coils and destroyed transistors.
The droptarget down is a very small coil, and the original transistor should be ok.
What I always do (as a preventive solution) is solder diodes on those 4 coils. That way it doesn't matter if the tieback diode has a bad connection. Diodes are very cheap and it's an easy job to do.
#6 8 years ago
If you have time, read this
https://groups.google.com/forum/#!topic/rec.games.pinball/wusSfhZ9IQg
and you will solve the problem.
- Ingo
#7 8 years ago
Quoted from Richard_BoK:
Salut,
Could you please precise this a little bit more (or even better illustrate with images)?
Thanks in advance,
Regards,
flugs
#8 8 years ago
I just solder a diode on the lugs of those 4 coils. The banded side is connected to the 50V supply (violet-green wire).
Exactly the same way coils are equipped with diodes on a non-WPC game.
#9 8 years ago
Thanks a lot for this explanation.
#10 8 years ago
Sounds like an excellent solution, to an obvious and potentially very damaging design flaw.
Rob Anthony
Pinball Classics
#11 8 years ago
Yes, very good suggestion.
In my case, there was a diode on the DT Down coil, which shorted and took the transistor with it.
#12 8 years ago
VERY common issue. Been helping a buddy with his STTNG, but never thought of the diode solution. I need to get over there and implement this!
