I bought my first pin (STTNG) a few months ago and my brother and I have been going through it and fixing all the issues. One issue we are facing is that Top Drop Down (solenoid #40) doesn't work. The only way the drop target drops is with a ball strike. We determined that the coil was bad so I've ordered a new coil. However there are a couple of observations with the mechanism that I'm wondering if they are normal or not. First is that the assembly that the coil moves to hit the drop target is resting against the PCB (see attached picture). This puts a fair bit of distance between the assembly and coil and it seems strange that the factory would design it like this. However I haven't seen any evidence of a broken stopper or other mechanism that the assembly should rest on. Is this normal behavior? I found a couple pictures of this assembly online and one had the assembly resting against the PCB while the other seemed to be resting much closer to the coil. Second, the spring that holds this assembly has alot of tension; more than seems necessary. Given these two factors it seems like the coil will have to work really hard to move this assembly and drop the target on command. Is this assembly mechanism working as expected or is there more I need to do than just replace the coil?
