(Topic ID: 228157)
ST:TNG Switch issue
By Xpinmonkey
5 years ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by pintechev
#1 5 years ago
Hi Pinside,
I have a switch issue with ST:TNG and am hoping you can figure it out because I am out of ideas. The game constantly put balls in the shooter lane. After hours of troubleshooting i found that switches #32 (Under L. Gun Sw.2), #42 (Under L. Lock Sw. 3) and #82 (Rift) all don't work. They are all in the same row #2. All other switches I tested worked just fine including others in row 2. I tried a know good xmit opto (it works with another opto receiver) and and soldiered in a spare receive opto for switch #32 as that was the first switch I saw out so I decided to start there but it didn't make a difference. I re-seated all cables on the cpu board and opto board under the play field with no change. Any ideas on where to start looking?
Thanks,
Brent
#2 5 years ago
I've performed the switch matrix diagnostics at http://pinwiki.com/wiki/index.php?title=Williams_WPC#Switch_Matrix_Problems
No issues were found. Every individual switch turned on/off. I assume that means I can rule out the CPU board as the issue?
#3 5 years ago
Do you have 12 volts? That’s what optical switches run on - I would check the driver board for the 12v fuse and see if it’s blown. Next up if that passes is to do continuity checks on row 2 and see where the continuity between switches stops.
Marc
#4 5 years ago
Thanks Marc! I figured it out.
I did have 12 volts and I started tracing the wires on row 2. I found there was a loose wire on the "left bank middle" switch #52. There was very little soldier to begin with on that part of the switch, surprised it held together for as long as it did.
#5 5 years ago
Great!
$ 63.95
7,000
San Diego, CA
6,000
Warner Robins, GA
$ 9.95
7,500 (OBO)
Elizabethtown, KY
$ 64.99
$ 15.95
Mitchell Lighting
$ 259.99
$ 399.00
$ 1,059.00
$ 19.95
Mitchell Lighting
$ 29.00
Filament Printing
Pinball Invasion
$ 22.50
5,850
Matthews, NC
$ 25.99
Lee's Parts
$ 599.00
Juz PINBALL Mods
$ 9.99
$ 1.00
Pinball Alley
$ 85.00
$ 250.00
Professor Pinball
$ 29.90
YouBentMyWookie
$ 27.99
Lee's Parts
This page was printed from https://pinside.com/pinball/forum/topic/sttng-switch-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
