I have a strange issue thats puzzling me. Every switch registers. But if there is a ball loaded in switch 41 (Under lock sw 1) and you test switch 51(l.bank top) it will read 2 switches number 51 and now 47 (under Borg hole). When you play the game if there is a ball loaded in under lock 1 and you hit the l.bank top switch the game starts a mode like you have hit the start mission hole. I understand why the game starts the mode because it thinks its getting that switch reading I just have hit a point where I am asking for any possible help??
I changed the diode on switch 41, I swapped a known good 16 opto board and even replaced the optos. And the game will start a mission when you hit the 41 switch. If theres no ball under lock1 game plays fine and will not start a mission like it suppose to.
HELP!
