Hi guys,
The spinner on my sttng is killing the speed of the ball.
This is a new machine to me and I am most definitely missing some bit around the spinner.
As you can see from this pic.
The problem is that the spinner sits at an angle in its "home" position.
And when the ball hits it,it makes contact with the bottom edge of the spinner first.
This causes a pinch between the spinner and the PF.
It looks like the spinner is too high in its bracket but it looks to be set up correctly at the same time.
Heres an illustration of the problem.(exaggerated a bit)
What am i missing here?
is the spinner on the wrong bracket?
Should there be a diode on that switch ?
