I know this has been covered in numerous posts here and there. But all of it I have read hasn't helped so far. This is on STTNG. Everything was working perfectly. DMD, gameplay, VUKs, audio. I slid it eight feet away on the leg levelers. There was a small amount of vibration due to the leg levelers on my concrete floor. Once in the new location I turned it on and the DMD says "slam tilt switch is stuck closed". I have read everything about this situation. So far haven't been able to track down the gremlin. Many times right now if I hit a flipper button or hit the coin door switches, it will reset the machine. I have reseated all the connections, ribbon cables, and have confirmed the switches are not stuck closed. I have also switched out the coin door switches with known working ones, and that did not correct the issue. With the error showing on the DMD, I can activate a coin switch or press both flippers and the game most of the time will shut down and reset, with the same error showing upon startup. I have tested all the diodes on the board that the coin door connects to and they all test correct (not sure if this would cause this issue or not). Any thoughts out there after a similar situation or possible cure?
