Not sure if I should resurrect this old thread or start my own but the symptoms were the same.
I've tried all the points made above, but I'm having the same issue with my GI in the J121-11 and J121-6 line. I have new connectors and pins, and I'm getting continuity to TRIAC and all other points as pointed out on the schematic made for pinwiki. I've tested everything from the topside to underside of the board and connectivity is perfect
I pulled the fuse and tested it, it's good.
I tested the AC voltage between J121-6 and J121-11 and there is none.
I've tested U1 pins with a probe as suggested here from Pinwiki:
"Failed 74LS374. This is rare too but easy to test following this procedure. You can also test the outputs of the LS374 by probing pins 2, 5, 6, 16 and 19 with your logic probe. At full GI brightness, these pins should test as "high"."
My probe showed all these pins on U1 to be low, not high, so what can I take from that? Is U1 dead? (I hope not).
I also tried this below and my probe was pulsing showing a signal was getting through to pin 11 of U1:
"U1 is "clocked" by the ASIC via the /TRIAC signal. If you have AC power present at J115, and no GI at all, it's possible that the /TRIAC signal is not getting through to U1. A logic probe applied to pin 11 of U1 will prove that the signal is getting through. "
I have new parts on hand for Q11 and Q12 but I don't want to change them without knowing they're dead... If U1 is dead I'll have to order one in. Question is how do I test Q12, Q11 to know if they’re faulty?
*edit: I just want to add that the next pin over, J121-5 has 6.8 volts AC.
