Hello all: My restoration of my STTNG is coming along nicely. I powered up the machine for the first time in about 10 years and I have at least 2 problems that I have identified.
First: Both of my cannons seem to rotate properly but are not lined up properly. Neither point directly at the wire loading ramp. How do you adjust the home position on the cannons?
Second: I have a problem with balls continuing to be loaded into the launcher and not being recognized in the trough. I did install new great lakes modular boards as the old boards looked like they have been through a war zone. I would like to replace the female connector on the emitter board as the operator has soldered the wires to the current connector which I'm guessing doesn't work too well with the new boards. Can anyone tell me what size and type of connector I need to get and how the wiring should be to each pin? Thanks for any and all help!!
