Quoted from Triumvirat73:PPS holds the licensing rights. Trying to circumvent that would be licensing piracy and I have no intention of getting myself perma-banned here.
If you print one for yourself and >only< yourself it should be ok. You could scan yours in, fix what's wrong with it "The hole for example" and print a new one. It gets hairy when you start distributing reproductions, thats when you get in trouble. I recently made reproduction TSPP cabinet decals. And I can't/won't sell them. But If I make them and put them on my own machine, no crime in that. As well, when/if you go and sell the machine with the decals attached. No crime in that either. You already own one panel. Making a copy to replace the one you have is not illegal, or at least I would assume. Music for example, you can make as many mix-tapes "copies" as you want. You just can't share/distribute it? Just don't make more than one, and don't sell them. You will be fine... Make It So
