New! Dark mode!
(Topic ID: 47092)
St:tng owners welcome aboard the uss enterprise
By Pinballgeek
7 years ago
  • 4,586 posts
  • 356 Pinsiders participating
  • Latest reply 1 day ago by Pin_Guy
  • Topic is favorited by 219 Pinsiders
There have been 1,275 images uploaded to this topic. (View topic image gallery).
There are 4586 posts in this topic. You are on page 60 of 92.
#2951 1 year ago
Quoted from bobukcat:
Did I miss something and you fixed the problem where you have 12V at the emitter instead of ~1.5V but the switch still doesn't work? If you point your cell phone camera at the emitter is it glowing?
If you have 12V at the emitter there is no need to see if the LED is glowing as the circuit is not drawing any current.
#2952 1 year ago
Quoted from pacman11:
The voltage isn’t correct on the transmitter it says -12
Sorry, I missed this information from your earlier post. Since you are measuring -12V you have your test leads backwards with the red lead on ground (black wires).
Why you have a reading of 12V...
12V is the source voltage for the circuit, however there is a current limiting resistor on the opto board that drops the forward voltage going to the IR LED to roughly 1.4V (there are many variables); this is a good thing as the maximum rated voltage for this specific part is 1.7V.
There is only two things that can cause this reading...
1) The IR LED is blown open ... this is an extremely rare failure mode for a diode.
OR
2) The diode is installed backwards or miswired placing the positive voltage on cathode and ground on the anode resulting in a reverse biased condition preventing any current flow through the diode.
I can see from your posted image that the second condition is true as you clearly have the black wires (ground) on the anode (A) and the source voltage (current limited 12V) on the cathode (K). Reverse the positions of these two wires and it should work fine.
#2953 1 year ago
Quoted from Pin_Guy:
OR
Ya see, I usually just tune out of these technical discussions for STTNG one you start replying but in this case I noticed something was amiss so I jumped back in JUST enough to get you primed again! Seriously though, every time I think I know this game well you take it to a whole different level, well done!
#2954 1 year ago
I'm glad you did as you mentioned a 12V reading and I was like ..."wait, what 12V reading...."
#2955 1 year ago
Would someone be kind enough to post a couple pictures of the cannon launch limit switches installed (the switches that prevents firing)? I don't think mine are oriented correctly and/or are the correct switches. I stared at them for longer than I would like to admit and it wasn't obvious to me how they should work. A good reference would be appreciated. I scoured the forums and the tubes and couldn't find a clear picture of both sides.
#2956 1 year ago
Quoted from RobF:
https://pinside.com/pinball/forum/topic/sttng-owners-club/page/36#post-3908111
#2957 1 year ago
Is there currently a shaker kit available for this game, noticed PINBITS used to but no longer has them on their site for sale ?
#2958 1 year ago
Hey all trying to help a non-Pinside out by seeing what the value of his machine is. It’s an import, very nice condition, no Pf wear. I cleaned the machine for him about 6 months ago which consisted of taking the entire top of the pf apart, cleaning, polishing and waxing. Game plays but the only issue is ... an opto in the ball through is not working so this need to be fixed and he doesn’t have the knowledge to do so (I am on the West coast so I can’t fix it).
Machine is located just NE of Pittsburgh, PA. He wants to sell to put the money towards a TZ. So he will sell outright or trade for TZ (+cash obviously).
A0034C1C-1B89-41FF-9A77-F73E895838F1 (resized).jpegE3FD2303-2F27-4E90-B351-86D18FB5D340 (resized).jpeg54E2418D-7E15-40D0-9AC6-3AB232FEE2F2 (resized).jpeg958D5A24-BC2C-4F10-BDD6-BA89FAA028CB (resized).jpegB5EFB61C-FF84-4B7A-8A3C-739AEBADD4FB (resized).jpegB770BE06-64B7-4102-A597-A021C3D21BEE (resized).jpeg
#2959 1 year ago
Quoted from meSz:
$ 4,000 to 4,300 range.
#2960 1 year ago
Quoted from pfinny:
Pshhh. More like $4,500 - $5,000 range.
Opto is a $60 and easy fix.
#2961 1 year ago
Got my STTNG at the end of October. When I first got it the left flipper was weak. Cleaned the opto for the flipper button and it got to better strength (comparable with the right flipper). Now a couple weeks ago something changed in the machine where all coils seem to be firing much stronger than they were before. One day all three flippers & the catapult started firing a lot stronger (and the feeds into the cannons seem to be a bit stronger now also). Both the catapult and shots up the right lane are now going so strong they're bouncing off the drop target past the pops and back down the right lane. I can't really get any balls to go into the pops anymore. I tried plugging into a different outlet and lifting the playfield to check things out but it's still continued playing in its newly amped up mode. In one respect it's nice because I'm able to make cleaner shots with the stronger flippers, but on the other hand I want to make sure something isn't wonky with the machine. Just wondering if I didn't realize it was playing weaker than normal before & it's now corrected itself somehow, or if something should be checked.
#2962 1 year ago
Quoted from EaglePin:
WPC games of this era are pretty sensitive to line voltage and my guess is that's what's changed on yours. The power supply is a pretty simple design so there's not a lot there that's likely to have changed to cause the game to play differently.
#2963 1 year ago
Quoted from meSz:
If these are original (non hacked) boards I can repair them for him; tell him to contact me and I will provide shipping instructions for him to send me both his opto boards; I will test/repair them both then send them back to him (shipping included) for $20.
#2964 1 year ago
Quoted from meSz:
I would consider trading my fully restored to better than new condition STTNG for a TZ ... just saying
#2965 1 year ago
Quoted from Pahuffman:
I'm not trying to knock the machine as it appears to be in decent shape for its age, but there is no way to estimate a value without seeing the entire machine.
I'm wouldnt jump on giving it any value so soon without having pictures of the under playfield wiring, backbox boards and connectors, neutral zone hole (single highest damage spot in the game) etc... the game also has no mods at (not that that's bad), cabinet and head damage, insert ghosting, something odd going on with the lock in the head (never seen that before).
#2966 1 year ago
Not to mention damaged ramps, damaged subway, etc. I paid $3,950 for my STTNG last year and honestly it was too much. Needed all new ramps and plastics. Connector issues. I could go on. Oh well...
#2967 1 year ago
Inpaid 5k for mine in December, and it does have quite a few flaws....but than again I am in SoCal, so you have to add the 10% sun factor onto any price.
#2968 1 year ago
I paid $4200 for mine with Color DMD installed in March but I got a pretty smokin deal on it. I bought it at TPF and I don't think the guy wanted to haul it back home.
#2969 1 year ago
Quoted from Pinball_Gizzard:
What. I have been looking for one of those for a while.. too bad I don’t live closer to Texas!
#2970 1 year ago
I just paid $4800 for mine. Really nice with laser cannons and both OCD boards. Not sure if it was a steal... just really wanted the game.
#2971 1 year ago
I have to assume the price reflects upon folks having bad experiences with this game from either broken features or the hard drains this machine can have that keep this machine on the low end of Williams Super Pins. IMHO Williams hit a grand slam with this title.
#2972 1 year ago
OR
After fixing the wiring on the recipter and messing with the connector now the opt next to it stopped working. I think I have a bad connection of the 16 opt board. So I am going to start replacing the connectors and see what happens. Thanks for your help.
#2973 1 year ago
There is tons of advice in this thread, but I am a bit lost on my issue anyhow.
Once in a while, my pin goes into ball search mode, and it won't come out of it. Only way to end it, is turning it on and off. I tested all optos and switches, and they are all working. No weak solder joints either.
I was told before that it would most likely be an opto that is going bad, but how do I found out which one, if it happens only sporadically (every 25 to 50 games) and I cannot find anything when testing?
#2974 1 year ago
Quoted from StrangeSubset1:
Next time it does this, don't turn it off; instead, open the coin door and go into switch test and take a picture of the switch matrix. Then find out where the balls are actually located...by comparing their true location to what the matrix is telling you should give you much insight into the issue. If you post the matrix picture here, I'm sure someone will tell you whats going on.
#2975 1 year ago
Should have thought of that myself....guess that is why you make the big bucks......well, at least you should.
Thanks.
Probably won't happen before the weekend, but I'll report back.
#2976 1 year ago
Thanks.
I’ve reflowed solder on the opto boards for a similar issue. They get cold out there in space.
#2977 1 year ago
Hope someone can help me, I've lost my GI. I played a game without issue on Saturday morning, then played another game later in the afternoon and the GIs were out. I didn't touch anything. In test the inserts, flashers, and backbox lights all work fine, just no GIs.
This appears to be something bigger than just bad fuses. Any ideas?
#2978 1 year ago
Quoted from Hammerhead:
Did you reseat the GI pins in the backbox? Are the connectors burned at all?
#2979 1 year ago
No, connectors were replaced a few years back
#2980 1 year ago
First off ... read the General Illumination Problems found at this link http://pinwiki.com/wiki/index.php?title=Williams_WPC#General_Illumination_Problems ... there is a lot of good info here.
There are 5 sets of GI lights each with its own fuse; what you need to do is look for a common failure point; there are a couple of things that cause cause this and range for easy to really bad.
The BAD:
Failure of your transformers 6.3 VAC secondary winding. This is extremely rare.
Easy:
Bad ribbon cable between CPU and PDB - flip it over and see what happens
Disconnected GI lighting cable from the transformer
Moderate:
Failure of PDB U1
#2981 1 year ago
Has anybody bought one of the mirrored backglasses from CPR?
#2982 1 year ago
Can anyone point me in the right direction for this issue? My probe switches all seem to be aligned and working. I have no switch errors at all in the game. It’s the last quirk I have on a massive cleaning I gave this bad boy. Maybe an opto issue but again, no switch errors reported?! Sorry for the hand tremor
Just reinstalled the gun handle right after repainting it. Not bad eh??
#2983 1 year ago
Following up as I’m still stumped. Everything seems to be testing fine. I did a factory reset. Is it possible this minor time difference is the culprit??? If so, how exactly do you adjust these switches?
#2984 1 year ago
Has anyone overcome the issue shown below? I have the exact same issue and am not excited about modifiying my brand new ramp....
Quoted from simplykind:
Has anyone installed the protectors for the alpha ramp? They dont line up on mine, almost need to modify the ramp. Im hesitant to cut off the corners of a brnad new ramp. And it seems like the posts need to be higher.
[quoted image][quoted image]
31BA2572-5C6E-407C-8A32-184B4AC44345 (resized).jpeg625DEC82-DE1E-406A-8BF7-2332C41184A7 (resized).jpeg
#2985 1 year ago
Edit: my bad, wrong ramp!
I had alignment issues with my delta ramp protectors not my alpha. I had to drill a new hole for my delta ramp.
#2986 1 year ago
Quoted from play_pinball:
Just realized the coil installed is a 26-1500 and not the original 23-800. Gonna do a quick swap in for a 23-800 and see if it solves my problems!
#2987 1 year ago
According to the video, the are operating correctly.
#2988 1 year ago
If anybody has an original translite and is interested in trading for this one, send me a PM. If you happen to have a spare, I'd trade you a NES mini and SNES mini for one. Just picked it up yesterday. Game is simply amazing.
#2989 1 year ago
Well I got the right coil swapped in and it’s still doing the same thing, acknowledging the trigger pull but not shooting the ball. But now, instead of gently pushing the ball back into play near the end of the rotation, it shoots the ball full power back into the habitrails
#2990 1 year ago
As some added info about the issue with play_pinball's STTNG the wiring harness on the problem gun was broken. I completely took it apart and repaired the break in the opto wire (purple i think?). It seems to be functional now from what we can tell. Even put a meter on the opto and ran the gun test to make sure the opto wasn't losing connectivity while in motion. No notable change on the meter when doing so.
#2991 1 year ago
Repairing the wire harness only works if you crimp on new connectors with brand new wire.
Soldering broken wire will only yield broken wire after so many turns of the turret.
Replace the entire harness with a brand new one... if one wire was broken; they all are suspect now.
I speak from experience.
#2992 1 year ago
Quoted from Zitt:
Realized we didn't check the coil power as it turns. Yup it's the harness again. Coil power wire also has a break in it. Replacement harness ordered. Not going to bother with trying to repair it again since obviously the OEM wire is so prone to breaking.
#2993 1 year ago
I've toyed with the idea of having replacement looms made; but I'm not sure they'd sell honestly.
Where did you end up ordering replacement looms?
#2994 1 year ago
Quoted from Zitt:
He hasn't actually ordered it apparently but will likely order from Pinball Heaven in the UK. It's around $25 before shipping. Marco seems to also sell it but they want $50. The only downside is there are 2 color substitutions on the one Pinball Heaven makes which kinda sucks but I have no idea where to source the wire to make it myself. Even if I did that it would cost way more than that in materials to do it.
https://www.pinball.co.uk/game-specific-parts/star-trek-tng/cannon-looms-for-star-trek-tng-h-17067/
https://www.marcospecialties.com/pinball-parts/H-17067
#2995 1 year ago
The BAD:
Easy:
Moderate:
Failure of PDB U1
Followed the steps in the pinwiki document, which seem to suggest the issue is off-board as there is no AC voltage at J120/J121. I've confirmed this by swapping driver boards with no change. Unfortunately pinwiki speaks a lot about on-board issues, but not too much about off-board.
Some of the GI kinda work; they aren't very bright but they do light. Examples would be the rollover GIs and the shield GIs. Does anyone have any ideas of how almost all of the GIs would spontaneously stop working all at the same time, and it doesn't appear to be aboard issue?
How would I go about checking the transformer 6.3 VAC?
#2996 1 year ago
Quoted from sataneatscheese:
If anybody has an original translite and is interested in trading for this one, send me a PM. If you happen to have a spare, I'd trade you a NES mini and SNES mini for one. Just picked it up yesterday. Game is simply amazing.[quoted image]
Ha. My 3 game collection plus one arcade is very similar. I have a LOTR instead of the JP and a off-road challange instead of your 1up.
#2997 1 year ago
You sir have excellent tastes.
#2998 1 year ago
Pinbits had them for 17each. I'd replace both.
#2999 1 year ago
Quoted from Zitt:
They're sold out and i'm fairly certain the pinball heaven kit does both cannons.
#3000 1 year ago
Quoted from pinball_ric:
That's a good deal if it's both canons. Seems a little too cheap; but if covers both canons; a win for a local Austin guy!
Trade
Machine - For Trade
Massapequa, NY
