Its not as bad as people make it out to be, if for some reason repetitive cleaning is needed to make them work, I would start looking elsewhere for the source of the problem; perhaps corroded connectors dropping the voltage, 12V low on the opto board to start with would effect them all. Keep in mind if the voltage to the UV LEDs are low to start with, the light they produce will be dimmer than it should be and the less tolerant they will be.
In my opinion, unless your machine is filthy, cleaning an opto should not be a repetitive function, if you go back to it a second time, break out your meter and if the voltage is good at the LED, just replace it.
Cost to purchase enough IR LED's to replace every one in the machine is less that $10 + shipping.
