Quoted from SantaEatsCheese:If you are going to go through this effort and it really only goes off during multiball, as a suggestion I was thinking of adding red LED strip lights to the rear and underside of the machine that were only on during borg multiball. Remember, it starts off with, "Red alert".
Here is an idea for you. Using the Wedge Style Lamp Scoops, typically used to add additional lighting to the playfield, I used (2) of them, mounted to the back of the backbox on opposite sides and shooting up. (You can't see them from the front of the machine). Installing the flasher style led in each one, and running a separate circuit wire pair to each.
Each flasher is PAIRED with the Borg Ship Flasher (left rear backbox external flasher with Left Borg Ship Flasher) and same for the right. You can tie into the flasher circuit behind the backglass or the circuit going to the flashers in the actual Borg Ship (they are the same and activate at the same time).
The effect is during the Borg Multi-Ball Gameplay, the additional flashers will strobe your ceiling area (in a dark room) enhancing the dramatic effects of the battle and explosions. This is an amazingly cool effect, almost like lighting in your room.
Granted it helps if your ceiling is white.....
I also have a "starfield generator" running, which the flashers override perfectly during that moment.
Someone in the early pages of this blog had mentioned doing this, so I gave it a try. Thank you if you're still on here for the suggestion.
