Quoted from Gingerbloke:Hi Eric - yes… I did the full tear down yesterday..
Broken ramp? Yes all of them. Including the subway. All hidden by protectors.
Broken scoop
Broken catapult
Broken drop target - 3 breaks..
Broken wireform (small weld job so easy)
Broken Cannon… - new cable ordered, I hope this is the issue. It turns but will not fire and the light does not flash so i hope its the cable.
Broken Plastics - 3
So - anything that could be broken is broken.
BUT.
The Playfield looks good and once I replace everything and add the playfield and plastic protectors it will look awesome And stay awesome!!
And - the more broken bits, the less I have to clean!!!!
Am in Europe so Pinball Center is my port of call.
Sounds like you have the sister machine to mine. I have replaced and rebuilt my machine from the ground up. Here is something to seriously do. Due to the condition of your machine, you are going to need to pull each (I mean EVERY) board out of the backbox and inspect everything.
Bet you have burnt connectors, maybe even board damage. The Power Driver board in the HEART of your system, and I replaced mine with a new Rotten Dog board. Suggest you reflow all the solder on everything. Likely you will also want to check all of your ground connections and install the Tie Backs.
Great and worthwhile upgrades include a color dmd and Pinsound Plus with speakers and headphone station.
check out my profile and you will see tons of photos on my machine.
Eric
