Hi everyone! New to the forum, and really to the wonderful world of owning these fabulous machines!
I'm having an issue with my ST:TNG that I am hoping someone can help me out with. Basically, after consistent play(maybe a solid hour), my lower right flipper stops working. Just drops and is completely non-responsive. Before that point the flipper is strong and works perfectly. I should also note that if the machine sits for a while it goes back to working normally, but the downtime is in the several hours range.
I have checked all my connections and everything looks great. All of the fuses on the boards appear to be fine. The flippers were rebuilt just prior to my purchase, but I went ahead and pulled the right one apart anyway to makes sure there was no gunk in the coil or any other obvious issues. The opto-boards and switches are clean.
I'm loving this machine and it's getting a lot of play, so I would like to trace this issue and fix it. I tried searching through posts on here for a similar issue, but did not see anything. If this is a common-ish problem and I can just be pointed toward some solutions I will take it!
