Hello everyone,
I'm having a problem with what started out as an intermittent problem with the opto located on the right vertical upkicker that feeds the cannon. For some reason that opto would only work occasionally. I replaced the opto but that didn't solve the problem. Still was intermittent. Now it doesn't register at all on the switch test. My question is can someone tell me where those wires end up (connector) at the board? I'm thinking it may be a bad connection but I'm not great at reading schematics. Any other tips for trying to run the solution down would be great. Thanks in advance!
Scott
