(Topic ID: 111841)
STTNG: None of cannon rotation switches register.
By creech927
9 years ago
  • 5 posts
  • 5 Pinsiders participating
  • Latest reply 3 years ago by Pin_Guy
#1 9 years ago
GReetings!
I've got a STTNG that has an issue. Neither the left gun mark, Left Gun Home, Right Gun Mark or right Gun Home switches register in test mode. I've gone into tests, set the guns rotated both so they're at about 45degree angles (as to get off all 4 switches) and put the game into Switch Edge mode.
With all 6 balls removed, The game shows the following:
Sw 24 - Closed
All of Column 3
All of Column 4
All of Column 6 except Switch 68 ( shooter)
When I attempt to click by hand any of cannon Mark or Home switches, nothing registers.
If I disconnect the violet/white wire at 8 driver board J5-1, nothing changes. Verified the purple/white wire at 0 ohms testing from J5-1 to the connector leading into the home and stop switches under the left cannon, where it terminates. (connection is solid)
If I disconnect the J209 from the CPU board, ALL the boxes in test mode clear except Column 2 row 4.
So it sounds like something is not registering the switch inputs from under the playfield for the violet/white column in the switch matrix. A visual inspection as well checking with a meter shows the purple wire isn't broken.
Now what's weird is I can take a wire and jump across the switches Middle and post and the non ring side of the diode on the switch and it will register 2 switch movements in rapid succession. (but activating the switch manually won't do anything) But it shows Switch 35/45, 36/46 on the right cannon and switch 37/47 and 32/42 on the left cannon. This tells me that the wiring in the game is capable of detecting those wires are getting signal back to the CPU, so I don't think this is a wiring issue.
This game was working fine last week, and has not been moved or stressed.
Any advise on what to check next?
-Greg
Post edited by creech927: update
#2 9 years ago
The cannon switches are not in the switch edge test mode. Don't know why. Go into the cannon test menu and you can verify they are working. This messed with me for a while as well.
#3 9 years ago
Jwo nailed it.
It sounds like your game still is working correctly and there is nothing to be concerned about.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
6 years later
#4 3 years ago
Quoted from jwo825:
Thank you! This was driving me crazy today. I’d like those 3 hours of my life back now ha ha
#5 3 years ago
Quoted from jwo825:
I know this is an old thread but I like to answer the "why" questions, cant help it.
These switches are not in switch edge test because they are not part of the switch matric. Since STTNG has > 64 switches which is the max switches you can control in an 8x8 matrix an additional aux driver board was added and one of the things it does is controls a CPU column 9 pulse which is where these switches reside, these switches are processed on that board and sent to the CPU as data along the grey flat cable.
More food for thought ... the spinner on STTNG is also not on the switch matrix, nor is it on the aux driver board; this switch is controlled by the Fliptronics board and is connected to the portion of the board that would be the Upper Left Flipper EOS switch on games that have one.
$ 85.00
$ 29.00
Filament Printing
6,000
Warner Robins, GA
$ 1,059.00
$ 27.99
Lee's Parts
5,700
Plymouth Meeting, PA
$ 25.99
Lee's Parts
$ 9.95
$ 15.95
Mitchell Lighting
$ 250.00
Professor Pinball
Lenticular Designs
$ 49.99
$ 19.95
Mitchell Lighting
$ 449.00
$ 29.90
$ 399.00
$ 259.99
$ 9.99
$ 22.50
6,250 (Firm)
Portland, OR
$ 1.00
Pinball Alley
$ 173.00
Sparky Pinball
6,000
West Chester, PA
