Had a STTNG delivered and seller said the color DMD may need some connectors plugged back in from a last minute ditch decision to swap it out with the original. The color DMD had all the connections hooked up and working fine but I have no opto power. Looked at power driver board and J117 was plugged into J118 and J118 connector was plugged into this little board pictured below which I have no clue what the little board is for. I'm guessing that J117 plugs back into J117 spot and there should be a extra connector going from little board back to J118 spot. Is this right?
