Hello all: I was playing a game tonight and my lower right flipper went dead. I just rebuilt the flippers about a month ago with the blue coils. What can I check to rule out the coil or diodes? Thanks everyone and Merry Christmas!!
I suggest you start with fuse F103 on the Fliptronic board. I experienced the exact same thing half an hour ago. Also rebuilt flippers yesterday. Next thing I did was check and reflow a the EOS wiring and it has been good since.
Is the right upper flipper still working?
Did you check the wiring, nothing loose?
And like shaneo said, check the fliptronic board and fuses
Check the fuse right next to it under the payfield.
I had a problem with my left flipper going dead intermittently and it turned out to be the fuse.
Good luck.
Great game.
Bill
Well, I have checked for a loose wire and everything is intact. Diode readings are equal to the left flipper. I checked J903 fuse on the fliptronics board and it had blown. Replaced and I'm back working again. And, yes, the upper flipper was working while the lower was not, Thor-NL. Thanks again guys!
This page was printed from https://pinside.com/pinball/forum/topic/sttng-lower-right-flipper-dead and we tried optimising it for printing. Some page elements may have been deliberately hidden.
