Whenever I choose "Light Lock" from the plunge menu, the game proceeds to lock 3 balls and start multiball. You can do this on ball 1 and ball 2. What could possibly be causing this?
I'm running LA-7 ROM
MK
MK
I think I may have found it:
Someone did a hack job fixing the drop target in front of the hole. I don't think it is working half of the time.
MK
Switch not registering in that hole back there behind the drop target? Diode off the switch? Have you looked under there?
It's going to be a switch issue. Dies the same also happen if you shoot the lock shit during game play? Does it just start MB on the first lock? You can probably find the problem in switch test. There are a lot of subway switches under the playfield. If one locked ball triggers them all then the game may consider three balls are locked instead of one.
This page was printed from https://pinside.com/pinball/forum/topic/sttng-light-lock-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
