Quoted from Occelot:Hey guys, is it possible to adjust the alignment of the left launcher? It is a little off and sometimes causes the ball to gets stuck where the ramp meets the launcher as it tries to load and then goes into ball search mode.
It is, you need to adjust the left cannons so that the home switch closes just before the crank reaches its apex; if you adjust it to close in the exact spot the cannon needs to be, the cannons momentum could carry it past a tiny bit. It sounds complicated, but it really isn't, you can accomplish this by either adjusting the switch itself, or loosening the four phillips screws that hold the cannon to the shaft and rotating it into position by hand; I would do the later as its much easier, but you may find that you will need to make a mark switch adjustment afterwards if the cannon wont fire when in the proper positions.
Quoted from Pin_Guy:Yep, just loosen them, turn the cannon and lock it down.
Don't know where I'd be without you on this restoration, Pin_Guy - thanks again. Perfect alignment.
IMG_0367 (resized).jpgWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/sttng-left-launcher-alignment-calibration and we tried optimising it for printing. Some page elements may have been deliberately hidden.
