This has been driving me nuts
I have replace the BR2 recitifer on my STTNG. It has been replaced at least 3 times which causes the game to reset while playing. The third time was with this one from pinball life which is rated at 600V instead of the typical 200V one
http://www.pinballlife.com/index.php?p=product&id=411
I followed many of the troubleshooting tips on pinwiki here
http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Game_resets
1. Line voltage tests fine
2. Ground is good
3. See no visible cracks in Driver board on 5V area
4. Checked all Diodes on flippers. Look fine
5. BR2 fails based on PINWIKI troubleshooting
After each replacement of the rectifier the game is fine for anywhere between 3-5 hours of play. After that the system begins resetting, you check the BR2 and its shot again
Only thing I have not checked is thermistor. That will be done after work today. IF this is fine I am at a loss and any advice would be appreciated
