My STTNG has never worked properly since I got it last year. I've worked on it off and on and can't seem to get anywhere. Some new problems came up today on top of the old ones unfortunately.
-flashers do not work. I changed br3-4 and 1 of the caps (I only had one cap so I forget the number but it was the top cap that I replaced). Did not fix the issue.
-when I put the board back in, the game started going haywire. It sounded like the game was in test mode with all the upkicks looking for a ball. It kicks the balls to the shooter and stages all the balls in the pf. When you start a game, it won't kick out any ball to the shooter, both guns constantly activate, and then the dmd freezes on Light Lock. Never had this happen before.
-in the coil test, the left flipper power and hold work, but the right and upper flipper only go through the power test ok (no hold). However, when you play the game all flippers flip and hold...just weakly.
-game constantly locks a ball when entering the subway. I cleaned the optos and they register. One seems like it easily falls out of alignment. Cleaning and realigning didnt fix.
Video...ugh:
