I recently replaced switch 23 (Made Middle Ramp) as the switch was old and not always triggering. The replacement seems to be working fine during gameplay; however, when the switch is triggered in the switch test it is also triggering the two switches next to it on the matrix. They are 33 (Under R Gun sw2) and 43 (Under L Lock sw4), which are both optos.
The game played fine for a bit, but then I started having a problem with the game kicking out two balls during play. The trough optos appear to trigger correctly in switch test, so I looked at the bottom diverter (when playfield is up) and it appears to be gummed up and not operating smoothly like the top one.
I'm planning to take the subway off to try and clean this bottom diverter as I think this is some source of the problem, but is there something else that could be off that I'm missing? Do I need to take the subway completely off to clean the diverter? Anything else I need to check while it is off if that is the case?
Appreciate any help, slowly trying to work through these issues as a new owner!
