New! Dark mode!
(Topic ID: 164546)
STTNG - I can't find this part
By ibjames
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by jadziedzic
#1 4 years ago
On my opto board there is a 5 pin idc connector, I've ordered a bunch of IDC connectors and cannot find the right one, either it is too big or too small. I think I've ordered every 5 pin idc connector from marcos and I still don't have the right one.. did I miss one? All help is appreciated. When I look in the manual it just says 5 pin connector, I don't see the part listed anywhere.
#2 4 years ago
It is a 0.1" IDC. Try Great Plains Electronics. They should have it.
#3 4 years ago
If you cant find 0.1" you may have better luck looking for 2.54mm pitch; and you are correct, Marco doesn't seem have the one you need, but in a pinch you should be able to make this one work http://www.marcospecialties.com/pinball-parts/5792-12116-06.
#4 4 years ago
does this sound right?
Part Number: CP100-05-LR
Connector, 0.1" Plug, 5 PinConnector, Plug
5 Pin, 0.1"
Locking RampPrice: $0.12
#5 4 years ago
The original Williams part number is 5792-12535-05, which corresponds to a Panduit CT-100F22-5. You need a "through" connector, not an "end" connector (which is what Marco sells) when the wires continue through the connector, as is the case for the one you show in your picture. It may be possible to cut through the nylon web on the side of an "end" connector housing to make it work as a "through" connector.
You could buy a couple of CT100F22-10-T connectors from a seller on eBay and cut them up to make a 5-position connector (search for item 390433363667).
There's also a chance I might have one of these at home; PM me and I'll check my parts stash.
