Hey guys, looking for some help on my STTNG. It has a few problems that all showed up within a day. I'm not a newbie to collecting, but am when it comes to doing my own repairs...willing to learn though. I just had knee surgery so standing for periods of time could be difficult. If I don't respond right away, it's probably because I'm on painkillers and couldnt get around to working in the machine that day. I'll do my best and I appreciate all your help.
-flashers do not work in backbox
-some lights are out on right side of pf and Borg ship
-missing 20V to the driver board. Checked the test points, nothing. Checked all fuses and are OK.
-CPU board LED not lighting up properly
-LED bulbs that are out in backbox, not on PCBs, come back on when I simply touch them with my finger. Is this normal?
I looked this up/talked with a few STTNG owners and it could be several things from bad bridge rectifiers to bad or missing capacitors, to reseating the chips, etc.
In addition to these known problems the game plays different minigames at the same time. When you pick the probe minigame it sometimes just skips over it and continues to play the star trek theme music, not giving me the chance to shoot the cannon because it doesn't load it. It doesnt allow you to cancel Data's suggestion for 10,000 points with the flippers either. Other times you will be in the middle of a mission and it will unexpectedly end the mission much shorter that it should. It allows you to play two minigames at once. For example, Q talks to you and the inserts are lit even when it says that Q's Challenge is over and you're shooting around the pf. Two different music clips play along with the associated sound clips from whatever minigames are going on. Separately, Borg multiball started without me even hitting a target associated with it. Sometimes the initial launch of the ball from the plunger changes your rank (eg: ensign to lieutenant). Balls are getting stuck all over the pf so gameplay stops and it activates all the upkicks, etc to find the missing ball(s). So there are all sorts of weird things happening with the game...I am unsure what could be causing all of this.
Looking forward to fixing this...thanks!
