(Topic ID: 282292)
STTNG Help
By Rkrall
2 years ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by Rkrall
#1 2 years ago
Technical assistance needed. To start, my electrical skills are not the best so please dumb down any assistance you can help out with. My left cannon wasn't firing so i tracked down the well documented broken wire. While diagnosing, at one point with the game on, I bumped a metal piece with a piece of metal and the game reset. No biggie right lol. Booted up fine, no problem, soldered broken wires back together on the cannon and worked fine. I did notice afterwards that i had the violets crossed on the gun but it still worked. I've fixed the crossed wires and the game plays fine now, probably played 20 games but now at random times (not during game), J114 blows. The display says check 114 and 115 but only 114 blows.
So what could be causing J114 to blow ?
Thanks all!
#2 2 years ago
A short in the lamp matrix maybe ?
In single lamp test, do all lamps light up normal or are some very bright ?
#3 2 years ago
Quoted from zaza:
The actual fix for this was a busted wire at the coin door. Soldered it back on and everything is good to go now. Thanks.
#4 2 years ago
Spoke too soon, blew again. Interesting that these lights are out on gen illumination playfield 1 test and the all bulbs test. Green white/green wires
#5 2 years ago
I believe this was self infused with an under sized fuse. F114 calls for an 8 amp and i was only using 5 amp.
Second question, drop target is not registered "light lock" when hit while target is up. All looks clean and connected underneath, any ideas ?
$ 63.95
$ 447.00
PinballReplacementParts
Armor and blades
This page was printed from https://pinside.com/pinball/forum/topic/sttng-help-4 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
