New! Dark mode!
(Topic ID: 163624)
STTNG Help
By brent149
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by brent149
#1 4 years ago
I was hoping someone could help me with some switch issues I'm having on my STTNG. I recently had to install new switches for both my gun motors. While they register as working in a switch test, they come up as the wrong switches such as left out lane, control grip etc. The weird things is all those other switches (like left out lane) test fine as themselves as well. Was hoping someone has ran into a similar problem they've had to fix. Thanks in advance for the help.
#2 4 years ago
Without looking at the chart, 2 switches reading as the same switch is usually a bad diode in my experience. Check the chart and I'll bet they are on the same wire and you have a diode out
#3 4 years ago
Thanks, I'll check that. You're right about them being on the same wire. Each time one reads incorrectly it's displaying the name of another switch on the same wire.
#4 4 years ago
Or you connected a diode or wire in the wrong spot. Pictures will help us.
#5 4 years ago
Here's a shot of my two left gun switches. I wired the right side the same.
#6 4 years ago
Is one of those switches really just wire wrapped and not soldered? Also that switch appears the diode lead and the bare wire could possible be touching.
#7 4 years ago
There's solder on the right side of the ground in that pic, but not much. I check and none of my wiring touching the other post on switch. Cleaned it up just in case but no improvement on the switch test.
#8 4 years ago
Quoted from brent149:
This is actually very common behavior for switch matrix problems; usually its related to a shorted or backwards diode. Yours appears to be properly wired, but those solder connections are going to cause you a lot of issues.
The picture below could be an illusion but, it sure does look like the same wire strand.
#9 4 years ago
I definitely see what you're talking about, but they're not really touching. I just went to trimmed up the wires to be sure and had no effect. I'll try resoldering my leads like you said and see if that helps.
3,800 (OBO)
Sale Pending!
Nashville, TENNESSEE
$ 28.00
$ 350.00
Pinball Basement
