Hi, Sorry I have 6 hours lag with you.
First, I measured voltage in game over mode, on the lugs of BB and PF flashers which are weakly lit or not lit all. 21Vdc on each. I also checked the location of J107, J122,J126 (PF) then J106, J124,J125 (BB) and checked voltages. They are ok. I replaced some dark bulbs, nothing changes.
Then I went in test mode - all lamp + flashers. On some flashers, no voltage at all. On others, the dim ones, a weak 0,3 vdc oscillating with the test pulses. I would have expected up to 20Vdc at the time the line is grounded.
It is not a single phenomenon. It applies to all. That's where we enter the Twillight Zone
Thanks for going on with your support
