Hi,
On my STTNG the flashers stopped working. I found that LED5 was off, and F111 was blown. After replacing F111, everything worked again - except 1 flasher. Replaced that, and all was well. For about 5-10 minutes, after which fuse F111 blew again. Thinking it could be a bad fuse, I replaced it again. Everything worked OK. I even used the testing menu to test everything: normal lamps, flashers, coils, screen, sound, etc. But again, after 5 - 10 minutes of game time it blew again.
Reading this forum, I concluded there's likely a bad flasher or flasher socket somewhere. To make the investigation easier, I tried to disconnect the backboard flashers by disconnecting J106. There's only a single wire coming from it: J106-5. It is documented as providing "+20V, to backbox flashlamps".
My expectation was that none of the flashers on the backbox would work, while the flashers on the playfield would work normally. (Well, perhaps until F111 would blow again.) What actually happened was that *all* flashers worked normally - the ones on the playfield *and* the ones in the backbox. I entered the testing menu, and basically ran all available tests: I did not notice *any* problem or *any* lamp/flasher not working.
Is it normal that disconnecting J106 does not result in any noticeable difference?
